StarTech.com 20 ft DisplayPort Cable with Latches - M/M
£38.34
Delivery:
Standard: 1-3 working days
  • Length: 6.1m
  • Stock Status: In Stock
Product codes
The DISPLPORT20L 20ft DisplayPort cable supports a maximum bandwidth of 10.8 Gbps, and is capable of providing higher performance than either HDMI or dual link DVI and supporting next generation multimedia applications with a maximum resolution capability of up to WQXGA (2560×1600).
The cable features small, USB-sized latching connectors, with support for 2-way display connectivity and optional audio support. This 20-foot DisplayPort cable is both HDCP and DPCP capable, ensuring that digitally protected content is displayed properly on the connected display.
Product Description StarTech.com 20 ft DisplayPort Cable with Latches - 2560 x 1600 - DPCP & HDCP - Male to Male DP Video Monitor Cable (DISPLPORT20L) - DisplayPort cable - 6.1 m
Type DisplayPort cable
Technology Shielded
Features Latched, molded
Length 6.1 m
Connector DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards RoHS, NEC-CMG
Colour Black
Designed For P/N: USB32DPPRO
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 20 ft Dis...
£38.34
