StarTech.com 20in Slimline SATA Extension Cable
£10.95
Delivery:
Standard: 1-3 working days
Key features
  • Add an extra 20in to your Slimline device connection, allowing for convenient installation of your hard drives
  • Backed by StarTech.com lifetime warranty, ensuring a dependable connection
  • Length: 50.8cm
  • Stock Status: In Stock
Product codes
Extend Slimline SATA power and data connections by up to 20 inches. The SLSATA20EXT Slimline SATA Extension Cable features one Slimline SATA male connector and one Slimline SATA female connector, allowing you to extend the distance/placement of slim SATA drives within a tower style computer case by 20in - in turn making it easier to position your Slimline capable peripherals (drives etc.) as needed.
Constructed of only top quality materials and designed for optimum performance and reliability the SLSATA20EXT supports full SATA 3.0 bandwidth (up to 6 Gbps) when used with SATA 3.0 compliant drives.
Product Description StarTech.com Slimline SATA Extension Cable - SATA extension cable - Serial ATA 150/300 - Slimline SATA (M) to Slimline SATA (F) - 1.7 ft - red - SLSATA20EXT - SATA extension cable - 50.8 cm
Type SATA extension cable
Interface Speed Serial ATA 150/300
Length 50.8 cm
Connector 13 pin Slimline Serial ATA - male
Connector (Second End) 13 pin Slimline Serial ATA - female
Colour Red
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 20in Slim...
£10.95
