StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M
£35.36
Select:
Delivery:
Product codes
Extend the distance between your USB 2.0 devices by up to 65ft. The USB2HAB65AC 65ft/20m USB A to B cable incorporates bus-powered active circuitry, which enables it to perform beyond the 5-meter limit of a standard USB cable.
The longer connection provides enough cable length to connect your USB 2.0 peripherals up to 20m away from your PC, Laptop or Server, allowing you to position your devices as needed.
This active USB 2.0 cable is designed with top quality materials for high durability.
Product Description StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - Long 20 m USB Cable - 20m USB Printer Cable - 1x USB A (M), 1x USB B (M) - Black (USB2HAB65AC) - USB cable - 20 m
Type USB cable
Technology Shielded
Length 20 m
Connector 4 pin USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: ICUSB232D
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 20m / 65...
£35.36
