The monitor privacy screen is easy to attach and remove. Simply attach the 23 inch privacy screen to your 16:9 aspect ratio display using the attachment strips or slide-mount tabs. This confidentiality screen filter is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Product Description | StarTech.com Monitor Privacy Screen for 23 inch PC Display, Computer Screen Security Filter, Blue Light Reducing Screen Protector Film, 16:9 Widescreen, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter - display privacy filter - 23" wide | Product Type | Display privacy filter - 2-way | Installation Type | Removable - plug-in/adhesive | Package Content | Cleaning cloth, adhesive strips, slide mount tabs | Display Screen Size Compatibility | 23" wide | Product Material | Plastic | Dimensions (WxDxH) | 51 cm x 0.2 cm x 28.7 cm | Weight | 98 g | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Display privacy filter |
Dimensions (WxDxH) | 51 cm - 0.2 cm - 28.7 cm |
Weight | 98 g |
Shipping Dimensions (WxDxH) / Weight | 61.1 cm x 37.4 cm x 0.5 cm / 430 g |
Display Filter | |
Privacy Protection | 2-way |
Aspect Ratio | 16:9 |
Surface Finish | Glossy/matte |
Scratch Resistant | Yes |
Miscellaneous | |
Mounting Kit | Included |
Features | Antimicrobial finish, fingerprint-resistant coating, +/- 30° visible angle, blue light reduction, dust protection |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
