StarTech.com 24in. Monitor Privacy Screen
£88.90
Delivery:
Standard: 1-3 working days
Key features
  • PROTECT SENSITIVE DATA: This monitor security filter provides privacy outside +/-30° viewing angle from the center of your 16:10 24" widescreen display, keeping data on your desktop screen confidential
  • EASY APPLICATION: Using adhesive strips that won't leave permanent residue, apply the removable privacy filter cover to monitor bezel w/ the side mount tabs or directly to the screen for long term use
  • BLUE LIGHT REDUCTION: In addition to protecting your data, this PC monitor privacy screen minimizes digital eye strain when working for extended periods of time by reducing blue light by 30% to 40%
  • DURABLE & EASY TO CLEAN: Flexible dual mounting options fit various monitor bezels to add a durable computer screen protector film to the monitor to protect from scratches, fingerprints & dust
  • REDUCE GLARE OR INCREASE CLARITY: Reversible computer monitor privacy filter retains sharp and consistent image quality in any lighting with an anti-glare matte-finish or a high-clarity glossy-finish
  • Accessory Type: Privacy Screen
Product codes
The monitor privacy screen is easy to attach and remove. Simply attach the 24 inch privacy screen to your 16:10 aspect ratio display using the attachment strips or slide-mount tabs. This confidentiality screen filter is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Product Description StarTech.com Monitor Privacy Screen for 24 inch PC Display, Computer Screen Security Filter, Blue Light Reducing Screen Protector Film, 16:10 Widescreen, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter - display privacy filter - 24" wide
Product Type Display privacy filter - 2-way
Installation Type Removable - plug-in/adhesive
Package Content Cleaning cloth, adhesive strips, slide mount tabs
Display Screen Size Compatibility 24" wide
Product Material Plastic
Dimensions (WxDxH) 51.9 cm x 0.2 cm x 32.54 cm
Weight 98 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£88.90
