StarTech.com 24in Internal 5 pin USB IDC Motherboard Header C...
StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F
£4.00
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • By connecting internal USB 5-pin devices directly to the motherboard header ports, you can eliminate the need to install additional internal USB port cards
  • Provides 24" in cable length, reducing strain and eliminating stress on the rear USB expansion boards, or front panel USB ports, as well as expansion card and motherboard port connections
  • Length: 60.7cm
  • Stock Status: In Stock
Product codes
Connect a front panel USB hub or card reader directly to a motherboard header connector. The USBINT5PIN24 Internal USB Cable features two 5-pin USB motherboard header connectors, enabling you to connect a front panel USB hub or card reader directly to the motherboard header ports.
This 24in/2ft cable provides a convenient solution for connecting multi-function front panels, or any device that relies on internal USB ports, directly to a motherboard or expansion card USB IDC (Header) connection, without having to install additional cards or run cables externally to the rear ports.
The 5-pin USB Header Cable is constructed of high quality materials and expertly constructed for durable performance.
Product Description StarTech.com 24in Internal 5 pin USB IDC Motherboard Header Cable F/F - USB cable - 60.7 cm
Type USB cable
Length 60.7 cm
Connector 5 pin IDC - female
Connector (Second End) 5 pin IDC - female
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 24in Inte...
£4.00
