StarTech.com 24in Internal USB Motherboard Header to 2 Port S...
StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter
£42.37
10 in stock
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: Mac, PC
  • Interface: USB
  • Stock Status: In Stock
Product codes
The ICUSB232INT2 USB to serial adapter lets you add 2 RS232 ports to any desktop system that is equipped with an available USB motherboard header. Unlike standard USB to serial cables, this cable is designed for use inside the PC case, affording an entirely internal solution with no mess or extra adapters needed.
This compact and simple USB adapter offers a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
Product Description StarTech.com Motherboard Serial Port - Internal - 2 Port - Bus Powered - FTDI USB to Serial Adapter - USB to RS232 Adapter (ICUSB232INT2) - serial adapter
Device Type Serial adapter
Form Factor Internal
Interface (Bus) Type USB
Ports RS-232 x 2
Dimensions (WxDxH) 12 cm x 6.8 cm x 1.9 cm
Weight 63 g
Data Link Protocol RS-232
Data Transfer Rate 115.2 Kbps
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 24in Inte...
£42.37
