StarTech.com 24in Internal USB Motherboard Header to Serial R...
StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter
£20.48
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: USB 2.0
  • Stock Status: In Stock
Product codes
Add an RS232 serial port to your system using a spare USB header. The ICUSB232INT1 USB to RS232 serial adapter lets you add an RS232 port to any desktop system that is equipped with an available USB motherboard header.
Unlike standard USB to serial cables, this cable is designed for use inside the PC case, affording an entirely internal solution with no mess or extra adapters needed.
This compact and simple USB adapter offers a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
Product Description StarTech.com 24in Internal Motherboard USB Header to Serial RS232 Adapter - serial adapter
Device Type Serial adapter
Form Factor Internal - low profile
Interface (Bus) Type USB 2.0
Ports RS-232
Dimensions (WxDxH) 12.3 cm x 4.5 cm x 1.2 cm
Weight 31 g
Cabling Type Serial RS-232
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 24in Inte...
£20.48
