StarTech.com 25 ft DisplayPort Cable with Latches - M/M
£55.70
Delivery:
Standard: 1-3 working days
  • Type: DisplayPort
  • Length: 7.6m
  • Stock Status: In Stock
Product codes
This high quality 25ft DisplayPort cable provides a connection of up to 25ft between a DisplayPort source and a DisplayPort display, with no loss of signal quality - more than double the typical DisplayPort connection distance limitation (16ft).
Featuring 26 gauge (AWG) pure copper wire, the cable includes aluminum and Mylar shielding to help eliminate EMI and RFI interference and maintain signal integrity without any degradation of quality.
Supporting a maximum bandwidth of 10.8Gbps and display resolutions up to 2560x1600 (WQXGA), DisplayPort is capable of providing higher performance than either HDMI or dual link DVI. Each cable features small, USB-sized latching connectors with support for two-way display connectivity and optional audio support. Plus, DisplayPort cables feature a unique micro-packet architecture that supports new display features as the DisplayPort standard is further developed.
This 25ft DisplayPort cable is HDCP and DPCP compliant, ensuring that digitally protected content is displayed properly on the connected display.
Product Description StarTech.com 25 ft DisplayPort Cable with Latches - 2560 x 1600 - DPCP & HDCP - Male to Male DP Video Monitor Cable (DISPLPORT25L) - DisplayPort cable - 7.6 m
Type DisplayPort cable
Technology Shielded
Features Latched
Length 7.6 m
Connector DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards RoHS
Colour Black
Designed For P/N: CDP2DPHD, CDP2DPVGA, DPPNLFM3, DPPNLFM3PW, GCMDP2DPMF, HD2DP, HD2DPVGADVI, HDMI2DP, HDVGADP2HD, MDP2DPMF6IN, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SV231DPDDUA, SV231DPDDUA2, SV431DPUA, SV431DPUA2, TB32DP2, USB32DP4K
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 25 ft Dis...
£55.70
