StarTech.com 25 ft DVI-D Single Link Cable - M/M
£21.49
Select:
Delivery:
Standard: 1-3 working days
  • Type: Display
  • Length: 7.6m
  • Stock Status: In Stock
Product codes
This 25ft single-link DVI-D display cable offers a high quality connection that allows you to get the most out of your high-end digital video card and flat-panel digital LCD monitor. With DVI-D technology, no digital-to-analog conversion is necessary, so the signal is delivered faster and stronger than a standard monitor cable signal. The plug and play-compatible, all-digital connection is also ideal for connecting laptop computers to digital projectors for crystal-clear presentations. By interfacing two digital signals directly, you'll experience faster, higher-quality images. This single-link cable works with virtually any DVI digital flat panel LCD monitor and allows high-speed DVI video data transmissions of up to 4.95 Gbps.
Product Description StarTech.com DVI Cable - 25 ft - Single Link - Male to Male Cable - 1920x1200 - DVI-D Cable - Computer Monitor Cable - DVI Cord - DVI to DVI Cable (DVIDSMM25) - DVI cable - 7.6 m
Type DVI cable - single link
Length 7.6 m
Connector DVI-D - male
Connector (Second End) DVI-D - male
Compliant Standards Plug and Play
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 25 ft DVI...
£21.49
