Confidentiality Screen Filter Blue Light Reduction Matte or Glossy 2-Year Warranty. The monitor privacy screen is easy to attach and remove. Simply attach the 27 inch privacy cover to your computer display using the attachment strips or slide-mount tabs. This confidentiality screen filter is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect Your Privacy
The privacy screen protector for desktop monitors is a great investment if you want to protect your privacy and security. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. You can have a peace of mind while working in the office or public environments because you know your widescreen is protected with the 30+/- degree privacy viewing angle.
The monitor privacy film is designed to filter blue light (390nm~480 wavelength) that can cause eye strain and can disrupt sleeping patterns.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The TAA compliant PRIVSCNMON27 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Product Description | StarTech.com Monitor Privacy Screen for 27 inch PC Display, Computer Screen Security Filter, Blue Light Reducing Screen Protector Film, 16:9 WideScreen, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter - display privacy filter - 27" wide - TAA Compliant | Product Type | Display privacy filter | Package Content | Adhesive strips, slide mount tabs | Colour | Transparent | Display Screen Size Compatibility | 27" wide | Product Material | Plastic | Dimensions (WxDxH) | 59.767 cm x 33.6 cm x 0.2 cm | Weight | 395 g | TAA Compliant | Yes | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ARMPIVOTE2, ARMUNONB1, FPPNEUSTND |
General | |
Dimensions (WxDxH) | 59.767 cm - 33.6 cm - 0.2 cm |
Weight | 395 g |
Shipping Dimensions (WxDxH) / Weight | 68 cm x 44 cm x 0.6 cm / 500 g |
Display Filter | |
Aspect Ratio | 16:9 |
Miscellaneous | |
Mounting Kit | Included |
Features | Anti-glare, matte, glossy surface, +/- 30° visible angle, blue light reduction |
Compliant Standards | RoHS, REACH, GSA |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
