StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable...
StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F
£3.15
Select:
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Molded strain relief prevents the cable from being bent at sharp angles at the TRRS connectors, to minimize the stress at the plug termination point
  • Provides greater flexibility by enabling you to move more freely, while working at your computer with VOIP applications (Skype, chat programs)
  • Length: 2m
  • Stock Status: In Stock
Product codes
The MUHSMF2M 4-Pole 3.5mm headset extension cable (2m) features a 3.5mm (1/8" TRRS) audio connector on one end and a 3.5mm (1/8" TRRS) audio connector on the other, making it easy to extend the reach between your hands-free headset or headphones, and your iPhone, mobile phone or laptop computer.
To ensure long-lasting performance, this high quality 3.5mm audio extension cable features molded PVC strain relief at each of the 1/8" TRRS connectors, which prevents the cable termination points from bending at sharp angles, in turn reducing the risk of cable damage.
To ensure proper hardware detection, it's recommended that the external headset be plugged into the adapter first, before the adapter is connected to the computer or mobile device.
Product Description StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F - audio Extension Cable for iPhone (MUHSMF2M) - headset extension cable - 2 m
Cable Headset extension cable
American Wire Gauge (AWG) 28
Length 2 m
Colour Black
Connector 4-pole mini jack - male
Connector (Second End) 4-pole mini jack - female
Features Moulded, strain relief
Designed For P/N: MUYHSFMM, MUYHSMFF, MUYHSMFFADW, SV211DPUA, SV211DPUA4K, SV211HDUA4K
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m 3.5mm...
£3.15
