StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable...
StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F
£4.81
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Allows you to extend the reach of your serial devices by up to 2 meters, reducing cable length restrictions and providing flexibility for positioning your serial devices as needed
  • Backed by StarTech.com lifetime warranty for dependable performance
  • High quality cable shielding helps prevent EMI interference
  • Length: 2m
  • Stock Status: In Stock
Product codes
Extend the connection between your DB9 serial devices by up to 2m. The MXT1002MBK Black Serial Extension Cable (2m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
Product Description StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - DB9 RS232 Serial Extension Cable - Male to Female Cable (MXT1002MBK) - serial extension cable - DB-9 to DB-9 - 2 m
Type Serial extension cable
Technology Shielded
Length 2 m
Connector 9 pin D-Sub (DB-9) - male
Connector (Second End) 9 pin D-Sub (DB-9) - female
Colour Black
Designed For P/N: IC232TTL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232PRO, ICUSB232V2, SV1108IPPWGB
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m Black...
£4.81
