StarTech.com 2m BS-1363 to C13 Y-Cable
£7.86
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect to two monitors securely, without placing strain on the cable
  • Maximize space on your power strip, surge protector or wall outlet
  • Guaranteed reliability
  • Stock Status: In Stock
Product codes
Power two devices at once from a single power outlet, perfect for dual-monitor setups. This C13 Y-cable lets you plug multiple devices into a single power outlet, to maximize the space on your power strip, surge protector or wall outlet. It's perfect for setting up dual-monitor workstations.
The cable length from the Y-split is 47 cm on each side. This gives you an extended reach for connecting to two monitors securely, without placing a strain on the cable.
The power-splitter cable can also be used for connecting a monitor and computer to the same outlet or any two devices that have a C13 power connection.
The PXT101YUK is built to exact specifications and is fully tested to ensure maximum performance.
Product Description StarTech.com Computer Power Cable - BS-1363 to 2x C13 - power splitter - 1.8 m
Type Power splitter
Features Service Vacuum Thermoplastic (SVT) jacket
Length 1.8 m
Localisation United Kingdom
Connector Power BS 1363 - male
Connector (Second End) 2 x power IEC 60320 C13
Rated Voltage AC 250 V
Rated Current 10 A
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m BS-136...
£7.86
