StarTech.com 2m Coax High Resolution Monitor VGA Cable with A...
StarTech.com 2m Coax High Resolution Monitor VGA Cable with Audio HD15 M/M
£12.72
31 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 3.5mm stereo plugs at each end provide audio and video connections on a single cable
  • Backed by StarTech.com Lifetime warranty
  • Extends your VGA signal to work with your monitor, splitters, and projectors
  • Length: 2m
  • Stock Status: In Stock
Product codes
Make VGA video and audio connections using a single, high quality cable. The MXTHQMM2MA 2-meter High Resolution VGA Cable with Audio is a high quality SVGA cable designed to provide the highest video quality possible through VGA - a single cable solution for connecting both video between a VGA video card and monitor, and audio connections between a sound card and external audio device.
StarTech.com's high resolution VGA cable with audio features high quality male-to-male coaxial VGA cable, and is designed to eliminate picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 2m Coax High Resolution Monitor VGA Video Cable with Audio - VGA cable - 2 m
Type VGA cable
Technology Double shielded twisted pair triple coaxial
Features Molded, thumbscrews, strain relief, ferrite core
Length 2 m
Connectors HD-15 (VGA) - male , Stereo mini jack - male
Connectors (Second End) HD-15 (VGA) - male , Stereo mini jack - male
Compliant Standards UL 2919, RoHS, NEC-CMG
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m Coax H...
£12.72
