StarTech.com 2m DVI-D Dual Link Monitor Extension Cable - M/F
£9.54
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Length: 2m
  • Stock Status: In Stock
Product codes
Extend the connection distance between your DVI-D digital devices by 2 meters. The DVIDDMF2M 2m DVI-D Dual Link Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 2-meters.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
Product Description StarTech.com 2m DVID Dual Link Monitor Extension Cable M/F - DVI extension cable - 2 m
Type DVI extension cable - dual link
Length 2 m
Connector DVI-D - male
Connector (Second End) DVI-D - female
Compliant Standards RoHS
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m DVI-D...
£9.54
