StarTech.com 2m HDMI Extension Cable - Ultra HD 4k x 2k HDMI...
StarTech.com 2m HDMI Extension Cable - Ultra HD 4k x 2k HDMI Cable - M/F
£10.62
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Gold-plated connectors help prevent corrosion, to ensure a high quality HDMI extension
  • Molded HDMI connectors with strain relief maintain durable, error-free audio-video performance
  • Type: HDMI
  • Length: 2m
  • Stock Status: In Stock
Product codes
Extend the connection distance between your HDMI-enabled devices by 2 meters. The HDEXT2M HDMI extension cable (2m) features an HDMI 19-pin (male) connector on one end and an HDMI 19-pin (female) connector on the other, providing an extra 2-meter connection distance between your HDMI-enabled devices.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI extension cables are expertly designed and constructed of only top quality materials to ensure high quality, high-definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
Product Description StarTech.com 2m HDMI Extension Cable - Ultra HD 4k x 2k HDMI Cable - M/F - HDMI extension cable - 2 m
Cable HDMI extension cable
Technology Shielded
American Wire Gauge (AWG) 28
Length 2 m
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m HDMI E...
£10.62
