The HDDVIMM2M, 2-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A high quality addition to any home theater, digital signage or multimedia application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
Product Description | StarTech.com 2m High Speed HDMI Cable to DVI Digital Video Monitor - adapter cable - HDMI / DVI - 2 m | Cable | Adapter cable - HDMI / DVI | American Wire Gauge (AWG) | 28 | Length | 2 m | Colour | Black | Connector | HDMI - male | Connector (Second End) | DVI-D - male | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Adapter cable |
Interface Supported | HDMI / DVI |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 2 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 18+1 pin digital DVI (Single-Link) - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
