StarTech.com 2m Left Angle High Speed HDMI Cable - Ultra HD 4...
StarTech.com 2m Left Angle High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M
Key features
  • Dependable performance is guaranteed, through a StarTech.com lifetime warranty
  • Ideal for neat installations in tight spaces
  • Offers a durable connection through minimized cable strain, using an angled HDMI connector
Product codes
Create Ultra HD connections between your High Speed HDMI-equipped devices, even in hard to reach areas and tight spaces. The HDMM2ML High Speed HDMI cable (2m/6.5ft) features an HDMI male connector on one end and a left-angled connector on the other, for a dependable connection between HDMI-enabled devices even with limited space around a device's HDMI port. The left-angled HDMI connector allows the shaft of the cable to fit neatly against a device's HDMI port, in such a way as to minimize the space required near the connection point, which helps make installation easier in narrow spaces and reduces strain on the connection.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
StarTech.com High Speed Left Angle HDMI Cable - HDMI cable - 2 m
Cable
HDMI cable
Shielded
American Wire Gauge (AWG)
28
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Angled connector
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m Left A...
