StarTech.com 2m Micro HDMI to DVI-D Cable - M/M
£12.58
Delivery:
Standard: 1-3 working days
Key features
  • Maintain durable, error-free Micro HDMI to DVI video performance, using molded connectors with strain relief
  • Ensure a high quality, corrosion-free connection through gold-plated contacts
  • Guaranteed reliability
  • Length: 2m
  • Stock Status: In Stock
Product codes
View your pictures or videos from your HDMI Micro-equipped Smartphone or other mobile device up to 2m away from your DVI-D display. The HDDDVIMM2M 2m Micro HDMI to DVI-D Cable enables you to view your presentations, videos and pictures saved on your HDMI Micro-equipped mobile devices (Tablet, Smartphone), on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 6ft (2m) Slim 3.5mm Stereo Audio Cable (MU6MMS).
The HDDDVIMM2M is designed and constructed for maximum durability, to ensure dependable performance.
Product Description StarTech.com 2m Micro HDMI to DVI-D Cable - M/M - 2 meter Micro HDMI to DVI Cable - 19 pin HDMI (D) Male to DVI-D Male - 1920x1200 Video (HDDDVIMM2M) - video cable - HDMI / DVI - 2 m
Cable Video cable - HDMI / DVI
Technology Shielded
American Wire Gauge (AWG) 30
Length 2 m
Colour Black
Connector DVI-D - male
Connector (Second End) Micro HDMI - male
Features Moulded, strain relief
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m Micro...
£12.58
