StarTech.com 2m Micro HDMI to DVI-D Cable - M/M
£16.14
Delivery:
Standard: 1-3 working days
Key features
  • MICRO HDMI TO DVI CABLE: 6.6ft (2m) Micro HDMI male to DVI-D (24-pin) male cable supports Full HD 1920x1200p, 60Hz/1080p video, Single link, 3.9 Gbps bandwidth, 24 Bpp (RGB) color depth
  • DURABLE: Full HD high speed fully molded video adapter cable with durable PVC jacket for high strength and reliability; Flexible PVC strain relief prevents fraying or damage due to repetitive bending or rough usage; Ideal for Commercial environments
  • QUALITY CONSTRUCTION: Micro HDMI to DVI converter cable constructed with 30AWG wire, gold-plated connectors, and superior EMI shielding with Al-Mylar foil and copper braid improve signal integrity and reliability, providing higher quality video and audio
  • APPLICATIONS: This cord connects Micro HDMI (Type-D) devices: GoPro Hero/Raspberry Pi 4/cameras (DSLR/Video)/Nikon/Canon EOS to your DVI-Digital monitor/DVI display/projector; Ideal for viewing on larger screens; works w/ Samsung/Dell/HP/Acer/LG monitors
  • SPECS: 6.6 feet (2 meter) | Black | HDMI Male (Type-D/Micro) to DVI-Digital (24-pin) Female | Gold-plated connectors | 30 AWG | 0.2" (5mm) OD | PVC Jacket | EMI Shield: Al-Mylar foil with 85% Copper Braid | Lifetime Warranty
  • Length: 2m
Product codes
View your pictures or videos from your HDMI Micro-equipped Smartphone or other mobile device up to 2m away from your DVI-D display. The HDDDVIMM2M 2m Micro HDMI to DVI-D Cable enables you to view your presentations, videos and pictures saved on your HDMI Micro-equipped mobile devices (Tablet, Smartphone), on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 6ft (2m) Slim 3.5mm Stereo Audio Cable (MU6MMS).
The HDDDVIMM2M is designed and constructed for maximum durability, to ensure dependable performance.
Product Description StarTech.com 2m Micro HDMI to DVI-D Cable - M/M - 2 meter Micro HDMI to DVI Cable - 19 pin HDMI (D) Male to DVI-D Male - 1920x1200 Video (HDDDVIMM2M) - adapter cable - HDMI / DVI - 2 m
Cable Adapter cable - HDMI / DVI
Technology Shielded
American Wire Gauge (AWG) 30
Length 2 m
Colour Black
Connector DVI-D - male
Connector (Second End) Micro HDMI - male
Features Moulded, strain relief
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£16.14
