StarTech.com 2m Micro USB Cable - A to Up Angle Micro B
£5.62
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 2m
  • Stock Status: In Stock
Product codes
Charge or sync your Micro USB devices over longer distances, with the cable kept out of the way. The USBAUB2MU 2m USB to Up Angle Micro USB Cable provides a high quality connection between your Micro USB 2.0 mobile devices (smartphones, digital cameras, Tablet PC devices, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The up-angled Micro USB connector allows you to access your mobile Micro USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a 2m USB to Down Angle Micro USB Cable (USBAUB2MD), which provides the same convenience as this up-angled cable, but allows you to connect to your Micro USB device from the opposite direction.
Product Description StarTech.com 2m Micro USB Cable Cord - A to Up Angle Micro B - Up Angled Micro USB Cable - 1x USB A (M), 1x USB Micro B (M) - Black (USBAUB2MU) - USB cable - 2 m
Type USB cable
Technology Double shielded
Features 90° connector, molded, strain relief
Length 2 m
Connector 5 pin Micro-USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m Micro...
£5.62
