StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC...
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - ST
£7.45
32 in stock
Delivery:
Standard: 3-5 working days
Key features
  • High-speed, high bandwidth transmissions over Gigabit Ethernet/fiber channel networks
  • LSZH-rated cable, suitable for installations under restrictive building codes
  • Resistant to pulls, strains, and impacts during your cable installations and maintenance
  • Length: 2m
  • Colour: Orange
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCST2 2m LSZH LC to ST Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-ST patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Product Description StarTech.com 2m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/ST - OM2 - LC to ST Fiber Patch Cable - patch cable - 2 m - orange
Type Patch cable - OM2
Technology Fibre optic
Type of Fibre Optics Multimode
Features Molded
Length 2 m
Core / Cladding Diameter 50 / 125 micron
Connector 2 x ST multi-mode - male
Connector (Second End) 2 x LC multi-mode - male
Colour Orange
Designed For P/N: MCM1110MMLC
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: 8M47 042722
£6.37
product
Customer return - item has been used and shows signs of use. PLEASE NOTE. Not in original packaging
Ref: 8M47 042723
£5.96
product
Ref: 8M47 042722
Accessories
Packaging
Functional
Software
Manuals
£6.37
product
Ref: 8M47 042723
Accessories
Packaging
Functional
Software
Manuals
£5.96
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
StarTech.com 2m Multim...
£7.45
