StarTech.com 2m Multimode 62.5/125 Duplex Fiber Patch Cable S...
StarTech.com 2m Multimode 62.5/125 Duplex Fiber Patch Cable ST - SC
£12.93
25 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Can maximize wiring conduit usage while minimizing installation problems
  • Fiber optic cables provide a higher quality signal over a greater distance
  • Fiber optic cables are an ultimate solution for high- speed data transmission
  • Backed by StarTech.com lifetime warranty
  • Length: 2m
  • Stock Status: In Stock
Product codes
Connect fiber network devices for high-speed transfers with LSZH rated cable. The FIBSTSC2 2-meter (6.6ft) Multimode 62.5/125 Duplex Fiber Patch Cable is terminated with one ST (male) connector and one SC (male) connector, to provide the necessary connection between fiber networking devices for high-speed, long distance networks.
This ST-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
To ensure optimum performance, the multimode fiber duplex cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
The ST-SC Multimode Fiber Patch cable is guaranteed to provide long-lasting dependability, and top quality performance.
Product Description StarTech.com 2m Fiber Optic Cable - Multimode Duplex 62.5/125 - LSZH - ST/SC - OM1 - ST to SC Fiber Patch Cable (FIBSTSC2) - network cable - 2 m
Type Network cable
Technology Fibre optic
Type of Fibre Optics Multimode
Length 2 m
Core / Cladding Diameter 62.5 / 125 micron
Connector 2 x SC multi-mode - male
Connector (Second End) 2 x ST multi-mode - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m Multim...
£12.93
