StarTech.com 2m Orange Gigabit Snagless RJ45 UTP Cat6 Patch C...
StarTech.com 2m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable
£3.86
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 50-micron gold connectors ensure optimum conductivity while eliminating signal loss due to oxidation or corrosion
  • RJ45 connector clip protectors help keep the plugs from snagging while routing the cable, for easier Cat 6 cable runs
  • Guaranteed reliability
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC2MOR Cat 6 Patch Cable (2m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable orange PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com Gigabit Snagless RJ45 UTP Cat6 Patch Cable Cord - patch cable - 2 m - orange
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless, minimised Near-End Crosstalk (NEXT)
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m Orange...
£3.86
