Power two devices at once from a single power outlet, perfect for dual-monitor setups. Maximize the outlets on your power strip, surge protector or wall outlet and free up space for other devices. This C13 power cord lets you plug two devices into a single power outlet.
The cord length from the Y-split is 50 cm on each side, giving you an extended reach for securely connecting your devices. You can power two monitors, or a monitor and a computer, or two switches in a rack, without placing strain on the cord.
The C13 power cord is fully tested to ensure maximum performance.
Product Description | StarTech.com 2m (6ft) Computer Power Cord, 18AWG, EU Schuko to 2x C13 Power Cord, 10A 250V, Black Replacement AC Cord, TV/Monitor Power Cable, Schuko CEE 7/7 to IEC 60320 2x C13 Power Cord - PC Power Supply Cable - power cable - CEE 7/7 to IEC 60320 C13 - 2 m | Type | Power cable | Length | 2 m | Connector | Power CEE 7/7 - male | Connector (Second End) | 2 x power IEC 60320 C13 | Rated Voltage | AC 250 V | Rated Current | 10 A | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Jacket Material | PVC |
Length | 2 m |
Colour | Black |
Weight | 295 g |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
The following resources are available for the StarTech.com 2m Power Cord Schuko CEE7 to 2x C13 - EU
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
