StarTech.com 2m QSFP+ Breakout Cable
£147.39
Select:
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Delivers reliable copper 40 GbE Ethernet connections
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
Product codes
Connect four MSA compliant 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies. It supports short-distance applications, such as point-to-point in-rack network switch or server connections, for up to four 10G SFP+ devices.
StarTech.com MSA Compliant QSFP+ Direct-Attach Breakout Cable - 2 m (6.6ft) - breakout cable - 2 m - black
Breakout cable - SFF-8431/SFF-8432/SFF-8436
Twinaxial
Passive cable
Length
2 m
Connector
QSFP+ - latched
Connector (Second End)
4 x SFP+ - latched
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m QSFP+...
£147.39
