StarTech.com 2m Snagless Cat6 Patch Cable - Blue
£3.86
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC2MBL Cat 6 Patch Cable (2m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a cheaper cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Product Description StarTech.com Gigabit Snagless RJ45 UTP Cat6 Patch Cable Cord - patch cable - 2 m - blue
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Wires per Cable 8 wires
Features Molded, snagless
Length 2 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m Snagle...
£3.86
