StarTech.com 2m USB 2.0 C to Micro B Cable
£16.14
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Charge and sync your USB 2.0 Micro-B devices from a USB-C host, over longer distances. This USB-C to Micro-B cable lets you charge and sync a USB 2.0 Micro-USB mobile device from a USB Type-C laptop. You can also charge your device using a USB-C wall charger, car charger or power bank, or connect an external Micro-USB drive for easy data backups.
The 2-meter cable gives you the length you need to overcome distance restrictions and stay connected. You can charge and sync your Micro-USB mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
You can also use the USB-C to Micro-USB cable to back up data to an external Micro-USB 2.0 drive from your USB-C or Thunderbolt 3 computer.
The longer cable lets you organize your desk to match your needs, enabling you to connect your device up to 2-meters away from your computer.
Product Description StarTech.com USB-C to Micro-B Cable - USB-C cable - 2 m
Type USB-C cable
Technology Shielded
Length 2 m
Connector 24 pin USB-C - male
Connector (Second End) 5 pin Micro-USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m USB 2....
£16.14
