StarTech.com 2m USB-C to DVI Cable
£27.43
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Get astonishing picture quality with support for video resolutions up to 1920 x 1200
  • Reduce clutter with a USB-C to DVI adapter and display cable, in-one
  • Make the perfect connection with a computer monitor cable that works with any USB-C enabled laptop
  • Stock Status: In Stock
Product codes
Eliminate clutter by connecting your USB Type-C computer directly to a DVI display, without additional adapters. This USB-C to DVI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DVI-I monitor, television or projector.
The adapter supports a connection distance of up to 2 m (6 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 2 m (6 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your DVI monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation. For shorter installations, a 1 m (3 ft.) USB-C to DVI cable enable you to choose the right cable length for your custom installation needs.
The USB-C to DVI adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
The adapter harnesses the video capabilities that are built into your USB Type-C connector to deliver video resolutions up to 2560x1600, providing full dual-link support for your high-resolution DVI monitors - great for multitasking on high-resolution DVI displays. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other HD work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
Product Description StarTech.com 6.6 ft / 2 m USB-C to DVI Cable - 1920 x 1200 - Black - external video adapter
Device Type External video adapter
Bus Type USB-C
Max Resolution 2560 x 1600
Interfaces DVI-D (male connector)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m USB-C...
£27.43
