StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F
£5.85
15 in stock
Delivery:
Standard: 1-3 working days
Product codes
Extend the length of your USB 2.0 cable by up to 2m. The USBEXTPAA2MW 2m White USB 2.0 Extension Cable features a USB ''A'' male connector and a USB ''A'' female connector, enabling you to extend the connection distance between your USB 2.0 devices by up to 1-meter - allowing for better placement of your peripheral devices, or adding flexibility to your existing USB ports.
The cable features thin USB connector moldings which allow you to simplify your connections, and plug into tight fitting locations.
StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F - USB extension cable - 2 m
USB extension cable
Double shielded
Molded, strain relief
Length
2 m
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
White
P/N: USBEXTPAA1MW
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2m White...
£5.85
