StarTech.com 2S1P PCI Express Serial Parallel Combo Card with...
StarTech.com 2S1P PCI Express Serial Parallel Combo Card with Breakout Cable
£31.62
Delivery:
Standard: 1-3 working days
Key features
  • Native single-chip design reduces CPU load for improved performance and reliability
  • Break-out cable design with low and standard profile brackets offers a versatile, single slot solution for adding 3 additional ports (2 serial, 1 parallel) to almost any system, including space-sensitive embedded applications
  • Broad Operating System support, including 64-bit Windows systems, for easy integration into mixed environments
  • Type: Parallel/serial adapter
  • Compatibility: Mac, PC
  • Interface: PCI Express x1
  • Stock Status: In Stock
Product codes
Add a parallel port and two RS-232 serial ports to your PC through a PCI-Express expansion slot. The PEX2S1P553B 2S1P PCI Express Serial Parallel Combo Card with Breakout Cable combines the functionality of Parallel and Serial cards, adding 2 RS232 serial ports and 1 parallel port through a single PCI Express (PCIe) slot. Suitable for almost any computer, the card offers a low profile/half-height design and includes an optional full-height bracket. The included break-out cable uses a single connector on the card to deliver 3 ports, avoiding crowded connections that can occur with fixed/static ports. Compatible with a broad range of operating systems including DOS, Windows? 7/Server 2008 R2/Vista/XP/Server 2003/2000/98SE (32/64 bit), Linux and Mac OS X. The card also features a native single-chip design that provides improved speed and reliability while reducing the CPU load by as much as 48% over conventional (bridge chip) cards.
Product Description StarTech.com 2S1P PCI Express Serial Parallel Combo Card with Breakout Cable - parallel/serial adapter - 2 ports
Device Type Parallel/serial adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
Dimensions (WxDxH) 2.3 cm x 9.5 cm x 7.9 cm
Weight 50 g
Ports Qty 2 ports
Auxiliary Ports 1 x parallel port
Data Link Protocol RS-232
System Requirements Microsoft DOS, Linux, Microsoft Windows 95/98 Second Edition, Microsoft Windows Server 2003, Apple MacOS X 10.4 or later, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2S1P PCI...
£31.62
