StarTech.com 2S1P PCI Serial Parallel Combo Card with 16550 UART
£31.54
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed compatibility with any PC running Windows, DOS or Linux for simple integration into your application
  • All three ports share only one IRQ, minimizing system resources required for the card
  • Easy to install and use with full step-by-step instruction providing a hassle free serial solution
  • Type: Parallel/serial adapter
  • Compatibility: PC
  • Interface: PCI
  • Stock Status: In Stock
Product codes
Add a parallel port and two RS-232 serial ports to your PC through a PCI expansion slot. The PCI2S1P PCI Serial/Parallel Combo Card turns a PCI slot into two external 16C550 serial ports and one external EPP/ECP parallel port - an all-in-one solution that gives you both parallel and serial connections while taking up only one PCI slot.
Suitable for installation in a small form factor computer, the PCI serial/parallel card includes an optional low profile/half-height mounting bracket that makes installation easy.
The serial/parallel combo card is PCI plug and play ready and supports IRQ sharing for fast, simple installation. The combo card is supported in virtually any Microsoft Windows operating environment (Windows 7, Server 2008 R2, Vista, XP, ME, 2000, 98, 95 and NT4).
Product Description StarTech.com 2S1P PCI Serial Parallel Combo Card with 16550 UART - IEEE 1284 Card - Serial Parallel PCI - PCI Serial Adapter (PCI2S1P) - parallel/serial adapter - 3 ports
Device Type Parallel/serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI
Ports Qty 3 ports
Cabling Type Parallel, serial
Data Transfer Rate 430 Kbps
System Requirements Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2S1P PCI...
£31.54
