StarTech.com 2s1p Serial Parallel Combo Mini PCI Express Card...
StarTech.com 2s1p Serial Parallel Combo Mini PCI Express Card for Embedded Systems
£30.42
Delivery:
Standard: 1-3 working days
  • Type: Parallel/serial adapter
  • Compatibility: PC
  • Interface: Mini PCI Express
  • Stock Status: In Stock
Product codes
Add two RS232 Serial Ports, and one Parallel Port to an Embedded System, through a mini PCI-Express Slot.
The MPEX2S1P552 2S1P Mini PCI Express Serial/Parallel Combo Card turns a mini-PCIe slot into two RS232 (DB9) serial ports, and one IEEE 1284 parallel port - a cost-saving solution for adding serial and parallel support to embedded systems that lack built-in serial/parallel functionality.
The 16650 UART adapter card features a native PCI Express single chip design, which enables you to take advantage of full PCI Express capability, by providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional "bridge chip" serial cards .
Product Description StarTech.com 2s1p Serial Parallel Combo Mini PCI Express Card for Embedded Systems - parallel/serial adapter - 2 ports
Device Type Parallel/serial adapter
Form Factor Plug-in card
Interface (Bus) Type Mini PCI Express
PCI Specification Revision PCIe 1.1
Dimensions (WxDxH) 3 cm x 5 cm x 1 cm
Weight 150 g
Ports Qty 2 ports
Auxiliary Ports 1 x parallel port
Data Link Protocol Parallel, serial
Data Transfer Rate 1.5 Mbps
Processor MCS9901CV-CC - MosChip Semiconductor
System Requirements Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux Kernel 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2s1p Seri...
£30.42
