StarTech.com 2S2P PCI Serial Parallel Combo Card with 16C1050...
StarTech.com 2S2P PCI Serial Parallel Combo Card with 16C1050 UART
Key features
  • Broad OS compatibility, including Windows and Linux for simple integration into mixed environments
  • Unique 2S2P card design allows you to add 2 Serial and 2 Parallel ports using only a single PCI slot
  • Universal support for 32/64-bit, 3.3/5V PCI or PCI-X slots makes this a suitable expansion card for almost any system
Product codes
Add two Serial and two Parallel ports to your desktop system through a single PCI slot. The PCI2S2PMC 2S2P PCI Serial/Parallel Combo Card (16C1050 UART) adds 2 RS232 serial, and 2 IEEE-1284 Parallel ports to your system, through a PCI slot. Supporting RS232 speeds up to 115.2 Kbps and parallel rates up to 1.5 Mbps, the serial/parallel adapter offers the added connectivity needed for industrial and business applications, while only occupying a single 3.3/5V PCI slot. This 2S-2P card offers a broad operating system compatibility list that includes Windows? 7, Windows Server 2003, XP, DOS? and Linux, for simple integration into mixed environments.
StarTech.com 2S2P PCI Serial Parallel Combo Card with 16C1050 UART - parallel/serial adapter
Parallel/serial adapter
Plug-in card
Interface (Bus) Type
PCI
1.9 cm x 13.3 cm x 8.9 cm
200 g
Parallel, serial
Microsoft DOS, Microsoft Windows 2000 / NT4.0, Microsoft Windows XP, Microsoft Windows 7, Linux 2.6.x, Microsoft Windows Vista, Windows 10 (32/64 bits)
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2S2P PCI...
