StarTech.com 2x SFF-8643 to 8644 Adapter
£67.54
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with 12Gbps SAS drives and backward compatible with 6Gbps SAS and SATA drives
  • Equipped with a full-profile bracket and includes a half-height/low-profile bracket for installation in small form-factor computers
  • Stock Status: In Stock
Product codes
Convert two internal SFF-8643 ports into two external SFF-8644 ports. This Mini-SAS adapter lets you convert two internal SFF-8643 ports on a controller card into two external SFF-8644 ports. This enables you to connect external SAS or SATA drives in devices such as a Direct Attached Storage (DAS) device to an internal backplane or SAS controller for additional storage.
The adapter can connect up to eight drives in total and is compatible with 12Gbps SAS drives as well as 6Gbps SATA drives. For installation in small form-factor computers, the adapter includes an optional half-height (low-profile) bracket, in addition to the preinstalled standard-height bracket.
Product Description StarTech.com Mini-SAS Adapter - Dual SFF-8643 to SFF-8644 - 12Gbps - SAS internal to external panel
Type SAS internal to external panel
Interface Speed SAS 12Gbit/s
Features Low profile
Connector 2 x 36 pin 4x Mini SAS HD (SFF-8643) - female
Connector (Second End) 2 x 36 pin 4x Mini SAS HD (SFF-8644) - female
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2x SFF-86...
£67.54
