StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cab...
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K
£32.95
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High Bit Rate 3 (HBR3) capabilities, providing bandwidths up to 32.4Gbps
  • Cutting-edge video quality with support for UHD video resolutions up to 8K 60Hz
  • Optimize your visual experience with the next generation of display technology
  • Reduce clutter with a combined USB-C to DisplayPort adapter and display cable
  • Make the perfect connection with a DP adapter that works with any USB-C enabled device including the 2018 iPad Pro
  • Interface: USB-C
  • Stock Status: In Stock
Product codes
This USB-C to DisplayPort adapter cable lets you connect your USB Type-C device to a DisplayPort monitor with just one cable, providing you with a convenient, clutter-free solution.
Supporting four times the resolution of 4K, this8K DP 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography.
The DP adapter is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
At 3.3 ft. (1 m) in length, this adapter delivers a compact connection that eliminates excess cabling, ensuring a tidy installation. For installations requiring a longer length, a 5.9 ft (1.8 m) (CDP2DP146B) DisplayPort cable enables you to customize your connection needs.
To ensure easy operation, this DP adapter supports plug-and-play installation, removing the need for additional software or drivers.
Note: Your USB-C device must support DP Alt Mode to work with this adapter.
Product Description StarTech.com 3.3ft/1m USB C to DisplayPort 1.4 Cable Adapter - 8K/5K/4K USB Type C to DP 1.4 Monitor Video Converter Cable - HDR/HBR3/DSC - external video adapter - black
Device Type External video adapter
Bus Type USB-C
Max Resolution 7680 x 4320
Interfaces DisplayPort (male connector)
Length 1 m
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3.3 ft. (...
£32.95
