StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable?
£23.97
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Versatile, bi-directional support lets you connect either your USB Type-C (or DisplayPort) device to a DisplayPort (or USB-C) display
  • High Bit Rate 3 (HBR3) capabilities, providing bandwidths up to 32.4Gbps
  • Cutting-edge video quality with support for UHD video resolutions up to 8K 30Hz
  • Compatible with Thunderbolt 3 and USB 3.1 Type-C ports that support DP Alt Mode
  • Reduce clutter with an adapter and display cable, in-one
  • Latching DisplayPort connector ensures a secure connection
  • Length: 1m
  • Stock Status: In Stock
Product codes
USB Type-C Adapter Cable 8K 30Hz Thunderbolt 3 HBR3. This USB-C  to DisplayPort  1.4 cable lets you connect your USB Type-C  (or Thunderbolt 3 ) device to a DisplayPort display, or a DP device to a USB-C display with just one cable.
Unparalleled Performance with Support for 8K 30Hz
Supporting four times the resolution of 4K, this 8K DP 1.4 adapter cable delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
The video cable is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
Easy & Clutter-Free Installation
At 3.3 ft. (1 m) in length, this bi-directional adapter cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For longer installations, we also offer a 6.6 ft. (2 m) USB-C to DP cable, enabling you to choose the right cable length for your custom installation needs.
Convenient, Bi-Directional Support
Use this USB-C to DisplayPort adapter cable to output 8K video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input. For added convenience, the cable supports both Mac & Windows operating systems.
CDP2DP141MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: Your USB-C device must support DP Alt Mode to work with this cable.
Product Description StarTech.com 3ft (1m) USB C to DisplayPort 1.4 Cable 8K 60Hz/4K - Reversible DP to USB-C or USB-C to DP Video Adapter Cable HBR3/HDR/DSC - USB / DisplayPort cable - USB-C to DisplayPort - 1 m
Type USB / DisplayPort cable
Features Active cable, 8K UHD (7680 x 4320) support, DisplayPort Alternate Mode support, bidirectional, High Bit Rate 3 (HBR3)
Length 1 m
Connector 24 pin USB-C - male (input)
Connector (Second End) 20 pin DisplayPort - female (output)
Compliant Standards USB 3.1 / Thunderbolt 3 / DisplayPort 1.4
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3.3 ft. (...
£23.97
