StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive...
StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps
£39.96
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 70% Faster than traditional USB 3.0, with UASP Transfer Protocol
  • Maximum durability, with aluminum housing
  • Type: Storage enclosure
  • HD Size: 3.5"
  • Stock Status: In Stock
Product codes
Turn a 3.5" SATA Hard Drive into a UASP-supported USB 3.0 External Hard Drive. The S3510BMU33 Black USB 3.0 Hard Drive Enclosure with UASP lets you connect a 3.5in SATA III hard drive (HDD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 3.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD enclosure is compatible with virtually any 3.5in SATA hard drive, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0/SATA III enclosure features high quality aluminum construction, ensuring durability.
Product Description StarTech.com 3.5in Black Aluminum USB 3.0 External SATA III SSD / HDD Enclosure with UASP for SATA 6Gbps - 3.5" SATA Hard Drive Enclosure (S3510BMU33) - storage enclosure - SATA 6Gb/s - USB 3.0
Device Type Storage enclosure - external
Bus Type USB 3.0
Colour Black
Expansion Bays 1 x internal - 3.5"
Hard Drive Form Factor Compatibility 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Supported Devices Hard drive
Max Storage Devices Qty 1
Product Material Plastic, aluminium
Power Source Included AC adapter
Power AC 120/230 V
System Requirements Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Dimensions (WxDxH) 3.14 cm x 19.15 cm x 11.54 cm
Weight 319.8 g
Designed For P/N: SVA12M2NEUA, SVA12M5NA, USBDUP15, USBDUPE115, USBDUPE17
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3.5in Bla...
£39.96
