StarTech.com 3.5in Trayless Hot Swap SATA Mobile Rack for Dua...
StarTech.com 3.5in Trayless Hot Swap SATA Mobile Rack for Dual 2.5in Hard Drives
Key features
  • Enables two 2.5in HDD/SSD to be installed into any free 3.5in drive bay without need of tray, caddy or carrier
  • Lockable drive doors add peace of mind and drive security
  • Providing a reliable HDD/SSD swapping solution this enclosure has an insertion cycle rating exceeding 15000 cycles
Product codes
Easily connect and swap two 2.5in SATA hard drives or SSDs through a single 3.5in front bay. The HSB225SATBK 3.5in SATA Mobile Rack lets you install two 2.5in SATA (SATA, SATA II, SATA III-6Gbps) hard drives (HDD) or solid state drives (SSD) into an available/unused 3.5in floppy drive bay.
The mobile rack delivers quick and easy access to hard drive contents, using a convenient "no mounting required/easy eject" feature which eliminates the need for the drives to be installed in a tray - a time-saving solution for instant drive removals and insertions, as part of a system building process or integration into rackmount systems or industrial environments.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
For added safety, the mobile rack is made from UL94 V-0 rated plastics and equipped with locking bay doors to help prevent accidental or unauthorized removal of the swappable hard drives. Also a perfect addition for operating system image deployment and any task that requires being able to access large volumes of data on the fly, the hot swap bay provides everything you need to expedite important projects while maintaining a reliable storage solution.
Product Description StarTech.com 3.5in Trayless Hot Swap SATA Mobile Rack for Dual 2.5in Hard Drives - storage mobile rack
Device Type Storage mobile rack
Colour Black
Expansion Bays 2 x hot-swap - 2.5"
Compatible Bay 2 2.5"
Hard Drive Form Factor Compatibility 2.5"
Supported Interface SATA 3 Gb/s
Drive Connector 22 pin Serial ATA
Features Data indicator, power indicator
Product Material Plastic, steel
Dimensions (WxDxH) 10.1 cm x 15.4 cm x 2.5 cm
Weight 224 g
Designed For P/N: PEXMSATA3422, PEXMSATA343, PEXSAT34RH
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
