StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Bac...
StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III
£77.10
Delivery:
Standard: 1-3 working days
  • Type: Storage mobile rack
  • HD Size: 2.5"
  • Stock Status: In Stock
Product codes
Easily connect and hot swap up to three 3.5" SATA/SAS hard drives from two 5.25" bays. The HSB3SATSASBA Removable 3-drive backplane lets you quickly install and hot-swap 3.5" drives from the front of your computer, by turning two 5.25" bays into a hot-swappable interface for you to connect up to three 3.5" SATA or SAS hard drives (HDD).
For added versatility, the hard drive bay can interface with SATA I/II/III and SAS I/II hard drives - an ideal accommodation for enterprise system applications.
For a quick and secure method of installing and removing drives, the backplane features ejection levers and a key-lock design. To help prevent drive failure, the bay provides excellent heat dissipation with a built-in fan, and a vented solid aluminum enclosure.
Product Description StarTech.com 3 Bay Trayless Hot Swap 3.5" SATA HDD Mobile Rack Backplane - storage mobile rack
Device Type Storage mobile rack
Colour Black
Expansion Bays 3 x hot-swap - 3.5"
Compatible Bay 2 5.25"
Hard Drive Form Factor Compatibility 2.5"
Supported Interface SATA-600
Drive Connector 29 pin internal SAS (SFF-8482)
Features Data indicator, power indicator
Product Material Aluminium
Dimensions (WxDxH) 14.5 cm x 19.41 cm x 11 cm
Weight 1.2 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 Bay Alu...
£77.10
