StarTech.com 3 ft 1s1p USB to Serial Parallel Port Adapter Cable
Key features
  • Drawing power from the USB bus saves the hassle of carrying an external power adapter for the add-on ports
  • Single cable USB to Serial and Parallel design enables two legacy devices to be connected to a host computer through a single USB port
  • Support for Windows and Linux operating systems allow for simple installation onto many desktop and laptop platforms
Product codes
Add one RS232 Serial, and one IEEE 1284 Parallel port to your computer through a single USB connection. The ICUSB2321284 1S1P USB to Serial/Parallel Adapter Cable enables you to connect DB9 RS232 serial devices and IEEE 1284 parallel devices to your PC or Linux laptop or desktop computer, through a single USB port, as though the computer offered onboard connectors. An innovative solution, the adapter cable features both a parallel and serial port that can be used simultaneously, delivering serial and parallel data rates of up to 921.6 Kbps and 1Mbps (respectively) to ensure optimum performance from your connected devices. Simple to install and use, the serial/parallel USB adapter is a cost-effective solution that bridges the connectivity gap between modern computers and legacy serial peripherals.
Product Description StarTech.com 1s1p USB to Serial Parallel Port Adapter Cable - parallel/serial adapter
Device Type Parallel/serial adapter
Form Factor External
Interface (Bus) Type USB
Weight 72 g
Data Link Protocol Parallel, RS-232
Data Transfer Rate 921.6 Kbps
Processor MosChip Semiconductor
Compliant Standards USB 1.1
Colour Black
System Requirements Linux, Microsoft Windows CE 5.0, Microsoft Windows Vista / XP / 7, Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
