StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Ca...
StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F
£15.69
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Provide power where necessary, using all 20 pins of the DP connectors
  • Configure your systems as needed, extend your DisplayPort connection by 3ft
  • Guaranteed reliability
  • Type: DisplayPort
  • Length: 91cm
  • Stock Status: In Stock
Product codes
The DPPNLFM3PW 3ft DisplayPort Extension Panel Mount Cable features one DP male connector and one panel mount DP female connector, providing a well-secured, easy to access DisplayPort connection on your PC or faceplate, and allowing you to customize your systems to suit your needs. If power is required, the DisplayPort Cable uses all 20 pins and can deliver power accordingly.
Product Description StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F - DisplayPort cable - 91 cm
Type DisplayPort cable
Features Latched, molded, integrated power connectors
Length 91 cm
Connector DisplayPort - male
Connector (Second End) DisplayPort - female
Compliant Standards RoHS, NEC-CMG
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft 20 p...
£15.69
