StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F
£1.52
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 91cm
  • Stock Status: In Stock
Product codes
The USBEXTAA3BK 3-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 3 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
Product Description StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F - 3 ft USB A to A Extension Cable - 3ft USB 2.0 Extension cord (USBEXTAA3BK) - USB extension cable - 91 cm
Type USB extension cable
Technology Double shielded
Length 91 cm
Connector 4 pin USB Type A - male
Connector (Second End) 4 pin USB Type A - female
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: 35FCREADBK3, ICUSB2321F, ICUSB232PRO, ICUSB232V2, LTUB1MBK, MSDREADU2OTG, ST4300USB3, ST4300USB3EU, ST4300USB3GB, SV221NANOU, UUSBOTG
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Blac...
£1.52
