StarTech.com 3 ft Cat 6 Red Molded RJ45 UTP Gigabit Cat6 Patc...
StarTech.com 3 ft Cat 6 Red Molded RJ45 UTP Gigabit Cat6 Patch Cable
£3.49
Delivery:
Key features
  • 100% copper - a better value
  • 24 AWG wire
  • 50-micron gold connectors
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH3RD Cat 6 Patch Cable (3 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Gigabit Patch Cable delivers reliable performance.
Product Description StarTech.com 3ft CAT6 Ethernet Cable - Red Molded Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz - Category 6 Network Patch Cord UL/TIA (C6PATCH3RD) - patch cable - 91 cm - red
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wires per Cable 8 wires
Features Molded
Length 91 cm
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Red
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Cat...
£3.49
