StarTech.com 3 ft DisplayPort to Mini DisplayPort 1.2 Video C...
StarTech.com 3 ft DisplayPort to Mini DisplayPort 1.2 Video Cable Adapter M/F - DisplayPort 4k
£9.88
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Cost-effective solution for adding a Mini DisplayPort connection to your laptop or computer
  • Guaranteed reliability
  • Stock Status: In Stock
Product codes
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort monitor and a DisplayPort source. The DP2MDPMF3 3ft DisplayPort to Mini DisplayPort 1.2 Cable Adapter turns a Mini DP male connector into a regular DisplayPort male connector, making it easy to connect a Mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Toshiba etc.).
The DP to Mini DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Product Description StarTech.com 3 ft DisplayPort to Mini DisplayPort 1.2 Video Cable Adapter M/F - DisplayPort 4k with HBR2 support - DP (M) to Mini DP (F) (DP2MDPMF3) - DisplayPort adapter - 90 cm
Type DisplayPort adapter
Features Molded
Length 90 cm
Connector DisplayPort - male
Connector (Second End) Mini DisplayPort - female
Compliant Standards RoHS, NEC-CMG
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
StarTech.com 3 ft Disp...
£9.88
