StarTech.com 3 ft DVI-D Dual Link Cable - M/M
£4.98
Delivery:
Standard: 1-3 working days
  • Type: DVI
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM3 3ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 3 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
Product Description StarTech.com Dual Link DVI Cable - 3 ft - Male to Male - 2560x1600 - DVI-D Cable - Computer Monitor Cable - DVI Cord - Video Cable (DVIDDMM3) - DVI cable - 91 cm
Type DVI cable - dual link
Length 91 cm
Connector DVI-D - male
Connector (Second End) DVI-D - male
Compliant Standards RoHS
Colour Black
Designed For P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2VGDVHD, DVI92030202L, HD2DPVGADVI, HDDVIMF8IN, MDP2DVI3, SV431DL2DU3A, USB32DVIEH
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft DVI-...
£4.98
