StarTech.com 3 ft eSATA and USB A to Power eSATA Cable - M/M
£12.12
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Allows connection of a Power eSATA device to a computer with regular eSATA and USB ports
  • Guaranteed reliability
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Connect power eSATA devices to the eSATA and USB ports on your computer. This eSATA and USB A Male to Power eSATA Cable provides a 3 ft connection between an external drive enclosure equipped with a power eSATA port and the eSATA and USB port on a PC/notebook, providing both power (through USB) and data (through SATA) using a single cable.
The 3 ft eSATA and USB A Male to Power eSATA Male cable is expertly designed and constructed of only top quality materials.
Product Description StarTech.com eSATA and USB A to Power eSATA Cable - Power Over eSATA cable - 91 cm
Type Power Over eSATA cable
Length 91 cm
Connectors 11 pin USB/eSATA - male
Connectors (Second End) 7 pin external Serial ATA - male , 4 pin USB Type A - male
Designed For P/N: S251SMU33EP
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft eSAT...
£12.12
