StarTech.com 3 ft HD15 to Component RCA Breakout Cable Adapte...
StarTech.com 3 ft HD15 to Component RCA Breakout Cable Adapter - M/M
£12.20
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • A cost-effective way of converting a VGA output port for connection to a display/monitor that uses Component video input
  • Easy to use and install
  • Backed by StarTech.com's lifetime warranty
  • Type: A/V
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Connect a VGA output (video card, etc.) to a display/monitor that uses Component video input. The HD15CPNTMM3 3ft HD15 to Component RCA Breakout Cable Adapter features a male VGA (HD15) connector and male component video connectors, allowing you to connect a VGA output (video card, etc.) to a display/monitor that uses Component video input.
This cable requires a video converter or output device that can process a YPbPr signal through an HD15 (VGA) port.
Product Description StarTech.com 3 ft. (0.9 m) VGA to RCA Cable - RCA Breakout - HD15 (M)/Component (M) - VGA to Component (HD15CPNTMM3) - VGA cable - 91 cm
Type VGA cable
Length 91 cm
Connector HD-15 (VGA) - male
Connector (Second End) 3 x RCA - male
Compliant Standards RoHS
Designed For P/N: DVI2VGA, VGA2HD2, VID2VGATV, VID2VGATV2, VID2VGATV3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft HD15...
£12.20
