StarTech.com 3 ft Micro USB Cable - A to Left Angle Micro B
£4.66
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Provides unrestricted access to your Micro-B USB devices, in landscape or portrait mode, even while charging
  • Guaranteed reliability
  • Length: 91cm
  • Stock Status: In Stock
Product codes
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB3LA 3-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The left-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a UUSBHAUB3RA 3ft USB A to Right Angle Micro B Cable, which provides the same convenience as this left-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
Product Description StarTech.com 3 ft / 91cm Micro USB Cable - A to Left Angle Micro B - USB Type A - 90 Degree Micro-USB Type B (M) - Black (UUSBHAUB3LA) - USB cable - 91 cm
Type USB cable
Features Molded, sync and charge
Length 91 cm
Connector 4 pin USB Type A - male
Connector (Second End) 5 pin Micro-USB Type B - male - 90° left-angled
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: ST4200MINI2, USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 3 ft Micr...
£4.66
